Car will not move
Old Jul 11, 2010 | 11:03 PM
25699z28's Avatar
Default Car will not move
had a convertor put in my car and the shop calls me and says when you put the car in any gear it wont move... is it the stall convertor or my trans.. i bought convertor used...
Old Jul 11, 2010 | 11:12 PM
98_LS1's Avatar
If the trans was fine before, I would say its the converter or improper installation of. Who installed it, did they make sure that the converter engaged 3 times when installing it on the trans? Did they make sure to bolt the 3 converter bolts to the flexplate???
Old Jul 11, 2010 | 11:51 PM
25699z28's Avatar
yes he says everything is right car jus wont move when it is put in gear... trans was fine when the convertor was put in.. any other ideas would be greatly apprieciated...
Old Jul 12, 2010 | 12:10 AM
98_LS1's Avatar
make sure all electrical connections to the trans are plugged in
Old Jul 12, 2010 | 12:12 AM
98_LS1's Avatar
and make sure the trans linkage is hooked up
Old Jul 12, 2010 | 12:29 AM
25699z28's Avatar
all are connected and hooked up
Old Jul 12, 2010 | 12:44 AM
98_LS1's Avatar
time for a new converter then.
Old Jul 12, 2010 | 12:50 AM
93sspcoupe's Avatar
did they fill the converter with fluid? i think they hold a few quarts by there self dont they?
Old Jul 12, 2010 | 11:36 PM
98_LS1's Avatar
is the driveshaft hooked up?
Old Jul 13, 2010 | 04:46 PM
1quickirocz's Avatar
i know a shop did this but ive seen people do stupid things. As stated before the converter if empty will suck up ALOT of fluid when its started. If the fluid was low already in the trans and the conver was dry the fluid could be low enough now that the pump cant pick it up. Just a thought but if thats not it then plan on another converter.
