TH400 Driveshaft Length!
1994 Camaro
Moser 9" w/ Strange S-series center 1350 joint
28" tire biased slightly rearward in the wheelwell
TH-400 short tail
Center of the yoke to output shaft was 46 5/8" with the car at ride height.
I still need to get my 12 bolt in so I can measure for my driveshaft(I'm running a TH350)
http://www.pstds.com/Images/driveshaft_measure.gif
It was 38, or 39 point something long. I forget now.
I got it from Bob @BruteSpeed, a chrome moly 1350 PST.
I'm using the GM 9.5" long Pontiac extension housing and output shaft on my th400, and my engine is also moved back 1" and a bit, over standard ls1 fbody.
Makes for a very cool short driveshaft!
The ford 9" 'long' yoke that is available, is 1" longer than the typical one.. so it will bring your driveshaft back very close to 10 bolt axle driveshaft length.
