Which Trans Brake for TH400?
Old Aug 6, 2010 | 06:36 PM
slow67's Avatar
Gingervitis Addict
Originally Posted by SuperSlow02
hmmmm I didnt know this, I have a "pro tree" transbrake in mine. Now by the way you said that it seems, the car wont accually go in reverse unless you engage the brake and let off it.? Is that correct? Mine will go in reverse fine without touching the button
The car will move, but theres a leak and not enough pressure in reverse, and the direct clutches slip.
Old Aug 7, 2010 | 12:09 AM
mr_biscuitz's Avatar
So if your not using a pro-tree brake then you can put it reverse and been fine?
Old Aug 7, 2010 | 10:43 AM
SuperSlow02's Avatar
just did a little research...from what I read it said it will not engage reverse without the button...obviously I dont have a pro tree transbrake...or Ck dosnt acually use a protree
Old Aug 7, 2010 | 03:14 PM
slow67's Avatar
Gingervitis Addict
Send Chris an email, he designed it, so he should know.
Old Aug 7, 2010 | 09:58 PM
jakeshoe's Avatar
The CK brake is a Pro-Tree design but it is different than most.
It does not require the button for reverse.
Many other brakes do, because as correctly stated previously, they leak in reverse, and when you apply the button it kills the leak and you get full pressure.
Old Aug 8, 2010 | 08:41 PM
how about the jw
