Stall help ASAP !
Some codes need to be disabled with a small diameter high stall converter.
P0757
P0751
Misfire tables need to be raised.
The rpm drop calculated between the engine rpm and vehicle speed in gear with a high stall speed will cause false 751 or 757 codes. These will also disable lock up which will cause the transmission to overheat.
Idle airflow can be changed to stop the engine from idling up and down at low speed, etc.
Its your converter clutch pressure. You have to delete tcc pwm on the ecu or change the valve on the valve body for it. This will give you max pressure to the tcc so it will lock upp on the highway. Ive dealt with that issue many times including my own car. Friends didnt listen to me and toasted their trans and the tc clutch...which is a smaller clutch on a smaller tc...which you now have.
To get max tcc pressure set the tcc pwm minimum table to 98.
It's far more common to have a false 757, 751, or misfire code disable tcc lock up entirely.
Theres a certain mail order tuner on here that does not increase tcc pwm, which I disagree with but apparently converters aren't burning up because of it.
BTW, OP, I remember once I was at a red light and when it turned green my car felt super sluggish and I got a solenoid B code. It only lets you drive in 2nd, or 3rd, cant remember, when it happens. Felt wierd. It happens sometimes if it gets stuck. I just deleted the code, jumped on the freeway and floored it to unstick it just in case. Problem and code never came back. At the time my trans was stock with a Yank SS 3600 and ecu tuning for more line pressure. Trans lasted 2yrs of abuse from 450rwhp. Not back for a stock one. I lost 4th gear and then I rebuilt it. Just trying to help.
