no overdrive after fixing simple leak!!!!
Old Aug 9, 2010 | 12:09 PM
BRKLYNZ28's Avatar
Default no overdrive after fixing simple leak!!!!
as im driving to work this morning my 96 4l60e trans dosnt want to go into overdrive for some reason.. yesterday after 2 month of a leaking trans pan gasket i pulled the pan cleaned it up put a new gasket on and put back the fluid that came out of it..plus two quarts. i was driving fine before that but just with a drip on the driveway from the gasket. o the filter also was changed. what do you think it is? the linkage is fine as i shifted 1-2-3. no 4th or od? any thoughts or test i should do when i get home from work.. its killing me that i stoped a simple leak and noW it dosnt shift lol..... any help would be great.. JOEY D
Old Aug 9, 2010 | 12:59 PM
Jays_SSZ28's Avatar
Theres a hole in the pan rail under the servo, make sure it's not blocked by the gasket.
No check engine light?
Check that the wiring didn't get bumped and all the solenoid plugs are in place.
Old Aug 9, 2010 | 03:36 PM
BRKLYNZ28's Avatar
well i got home and i got a 1870 code on the scanner.. so what next.. lol all this for changing a gasket...
Old Aug 9, 2010 | 03:59 PM
72blownvert's Avatar
That code did not pop up from changing pan gasket.1870 "transmission Componant slipping" is usually the torque converter slipping.The most common problem is the tcc regulator valve in v/b.Other problems are 1) afl valve in v/b 2) lock up solenoid 3)converter 4) stator bushings are worn out.
Old Aug 9, 2010 | 04:22 PM
BRKLYNZ28's Avatar
it just happened this morning when i went to work. i never got a code like that before ..maybe it got jealous...i get that alot latly when i work on my camaro and the truck is watching...lol...shes been towing a small trailer latly but only 40,000 on her.. i went on ebay and found a transgo kit hd that say it will fix the problem. and a power valve. what do you think i should do and replace while i pull the pan again?
Old Aug 9, 2010 | 07:02 PM
I would change the lock up solenoid also.
Old Aug 10, 2010 | 04:55 AM
omarrakeen's Avatar
same thing happened to me it leaked for a month i was too busy to fix it then car wouldnt get into 4th..i changed the filter and everything was fine..when did u change yours?? if u did before it started leaking then i recomend that u change it again, also check your solenoid as stated above. good luck
Old Aug 10, 2010 | 07:52 AM
BRKLYNZ28's Avatar
yea it was leaking for a few months but nothing bad. on one the bolts had fluid passing threw it even with sealent so i figured ill change the gasket.. and then no overdrive lol. i was looking on ebay and found a 1870 repair kit with gaskets,transgo plate and fix,and upgraded pistions fro 109. ill also buy another lockup as stated above with new a and b solenoids. they dont cost much so ill put them in while its out.. i was thinking about the transgo reprogramer but it said it needs stock pressure and my pcm tune boosted it up already. dont feel like reprograming it as it just a street truck.
Old Aug 10, 2010 | 09:39 AM
performabuilt's Avatar
LS1Tech Sponsor
Well with no forth and 4th being comanded the rpm may be to high and cause the 1870 code. If you inadvertedly blocked the small hole at the servo pan gasket area you will not have 4th, Since changing the gasket is all you did thats where i would look first
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 10, 2010 | 11:47 AM
BRKLYNZ28's Avatar
REALLY.. theres a small hole next to the gasket? well that sounds like that would do it. ill pull it off when i get home.. where is the location of this hole?
Old Aug 10, 2010 | 12:19 PM
The hole is just under the servo on the pan rail.You will see the pan has a little notch where it mates up to case.
Old Aug 10, 2010 | 04:06 PM
Jays_SSZ28's Avatar
Read the first reply.
