transmittion rebuit kit..
BTW when you make a post at 4am you might not get a response back as quick as you would think. To be honest I only look over the boards every so often and I'm sure that is the same with others. Being that you did not get a reply by 10am that should tell you something. Next time give it some time and I'm sure someone will chime in. Get a tune and I'm sure your car will perform better. Vince
haha ur right about that well i havent noticed the time diff. it was only till after i posted it that i have noticed the time diff. were i live it was about 5p.m.
thats for the reply i have a great tunner actually hoping for all to go wel..
If the old transmission worked at one time off the same tune, then the new trans should also.
So when you take your foot off the gas and let it shift does it hold when you get back on the gas? If it does hold it may be tuning. If it doesn't hold it's in the transmission.
