Anyone know what this is (4L80E Plug)
Old Aug 15, 2010 | 08:09 PM
LS13.5's Avatar
Default Anyone know what this is (4L80E Plug)
Anyone know what that is?
Im towards the end of a LSx/4L80E swap in an S13. Last part is the wiring, not sure if I need whatever plug this is...
The pins go to the "Trasmission Range Sensor" spots on the PCM.
Have the PCM de-pinned and just wanna know if I need to repin this or not.
Thanks in advance.
Old Aug 15, 2010 | 08:23 PM
FLT's Avatar
FLT
You are correct that would be for the manual range sensor or neutral switch. If your vehicle already has one at the shifter assembly then you probably will not need it. Unless you are using the one that would normally be on a truck trans then it will more than likely be needed. What type of vehicle are you working on?
Old Aug 15, 2010 | 08:49 PM
LS13.5's Avatar
Its going into an S13...
A manual one. I figured Id just go to a junkyard and find an auto shifter out of a camaro.
Would that already be attached to the shifter assembly?
Again, thanks for the response!
Old Aug 15, 2010 | 10:44 PM
FLT's Avatar
FLT
The shifter assembly from a f body will have the switch.
Old Aug 16, 2010 | 09:57 AM
LS13.5's Avatar
So then I can just toss this plug then?
Thanks.
Old Aug 28, 2010 | 07:46 AM
NoClassic's Avatar
Still have that T56?
You were sent payment nearly two months ago for a T56 and never shipped or delivered the part.
Old Aug 28, 2010 | 10:01 AM
FastKat's Avatar
Those wires go to the PCM and tell the PCM what gear the gear selector is in.
