Low RPM In Reverse 3500 Stall
Old Aug 26, 2010 | 12:57 PM
kb274868123's Avatar
Default Low RPM In Reverse 3500 Stall
I had a 3500 stall put in about three weeks ago and in reverse it feels very loose. It take a bit to get it moving but once its moving and i let off the gas the RPMs drop to about 350 to 400. When this happens the computer corrects it by bring it up to around 700 and then it goes back down to a steady 500 RPM. It does not do this when it is in drive only in reverse. Is this normal or do I need a tune? at WOT the RPMs do not hit the rev limiter or anything so i think the Frost tuen that i got before the stall is working well enough to hold off on another tune until I get my cam.
Old Aug 26, 2010 | 11:07 PM
daniel6718's Avatar
Id have the tune adjusted accodingly. The computer can calculate slip.
Old Aug 27, 2010 | 06:30 AM
skat's Avatar
Mine has been tuned after my stall, but with that said it foes the same thing. Even has died completely a couple of times. I am not worried I get it rolling then shift to N and let it roll, stop shift to D and no problems. I used to doing it now.
Old Aug 27, 2010 | 07:26 AM
Yea mine has died on me a couple times also. It seems to be better the slower I back out. By giving it to much gas to backup quickly might be causing the stall to flash higher then it normally would. Does it die on you everytime you try to backup in reverse?
Old Aug 27, 2010 | 06:42 PM
skat's Avatar
Not everytime it seems like more when I am on then off it quickly. I just go N and roll everytime do not even think about just habbit now.
