Fluid out the vent tube?
Old Aug 29, 2010 | 07:51 PM
dshannon's Avatar
Default Fluid out the vent tube?
1998 GMC Jimmy, 4l60e.
Fluid is coming out the transmission vent tube in the engine bay while I'm driving, which falls onto the exhaust, making a big stinky smoke cloud. I've been keeping an eye on the fluid and topping it off when needed.
I've read that this could be caused by a clogged cooler and/or cooler lines. I haven't checked this yet, but in the event there is a clog, I need to know what parts to buy.
I was just going to replace the whole system with new aftermarket tubing and lines. What fittings do I need to screw into the transmission that I can clamp hoses to? If anyone has done this, or can give some advice, I would greatly appreciate it.
Old Aug 29, 2010 | 09:21 PM
Jays_SSZ28's Avatar
More common is a 1870 DTC - converter not locking up causing the trans to run hot.
Old Aug 29, 2010 | 09:37 PM
dshannon's Avatar
My convertor locks up just fine.
By the way, I got my info from here: http://www.s10forum.com/forum/f13/4l...utions-297698/
Look at #28
Old Aug 29, 2010 | 11:10 PM
Jays_SSZ28's Avatar
I got my info from a car I worked on that was puking fluid out of the vent, the owner said it was locking up....it wasn't. I fixed the problem, it locked up, stopped puking fluid.
Old Aug 30, 2010 | 03:29 PM
dshannon's Avatar
Ok, well, just to make sure, at 60mph in OD, I'm at about ~1800rpm, and at 70mph I'm at ~2050rpm. Does that sound about right with a stock truck TC? (Not trying to sound offensive if I came off that way, I appreciate the input)
Old Aug 30, 2010 | 04:29 PM
Jays_SSZ28's Avatar
Pretty close. Using my calculation, and assuming the typical truck like yours has 3.42 gears and 28" tall tires those numbers come almost right on.
A better test would be to drive when you think the converter is locked up and push the gas a little more, not enough to unlock it, then tap the brake pedal and look at the tach.
Old Aug 30, 2010 | 06:58 PM
Badazz 97 TA's Avatar
too much fluid. Thats what happened to mine when i had it over filled slightly. i drained some out and it went away
Old Aug 30, 2010 | 09:37 PM
Detroit Gearbox's Avatar
X2. Use/borrow a scan tool and take a long drive. Check the tcc slippage and fluid temp.
Old Aug 31, 2010 | 06:55 PM
dshannon's Avatar
Well, I did the tap the brake test earlier today, just to make sure, and the TC is definitely locking up. There is a ~2-300rpm difference with lockup. I'm going to be taking it to a shop soon, well see how quickly they recommend I rebuild it lol.
