difficulty to install converter?
i like doing everything myself so i have peace of mind that its done correctly and no one ***** with my car, but im not sure if i have the experience or knowledge to tackle this one myself with my buddies. anyone know anyone in the general kansas city area that would be able to help me out?
i have never removed a transmission before but ive got a feeling my rear main seal is leaking so i gotta replace that so why not swap stalls while im in there?
One little tip that i wish i had known when reinstalling mine that doesnt seem to get mentioned a lot (or atleast i never saw it until i searched a bit)... the coolant lines on the transmission... install the clips before you try and reinstall the cooling lines. the cooling lines just push in with the clips in place. I cant even begin to tell you how pissed i got trying to hold in the cooler line then slide that clip over with that limited space. I wanted to push my car off the jack stands and set it on fire... LOL
Other then that get yourself a 13mm(i think) swivel socket and that will make life much easier as well!
good advice,
try this also
Johnny
>>>>> http://modernmusclecars.net/forums/a...p?do=tcinstall
https://ls1tech.com/forums/automatic...allations.html
may make a tool to hold flywheel
hope the drawing of tool is understandable
use a 1/8 x 2 flat bar about 12 in long insert into flywheel threw the round hole in botton of bellhouseing ,the notch in side will hold tool in place
PS:::
for some reason my drawing will not post right >>the base of the tool should be as wide as the top part with the teeth
i have an impact swivel and a 3ft extension. those 2 tools makes the job so much easier.
the other truck about the lines is a good idea. ive learned how to place the E clips facing the right way for easy removal and then just pop the lines out, but putting them in is tough at times. i may have to do this the next time i have the trans out
The things everyone has has said about the swivel and the "e" clips are so true, the clips are a pain. You might even want to get some new ones as sometimes when you remove them they can fly somewhere and you might never find them. Just take your time and if something is giving you fits take a break for a while and come back to it. Good Luck.
