Stall question
for example,a 3500 stall with 3.73s' would feel like a 4000 stall with 2.73s' and feel like a 3000 stall with 4.56s'. the stall slips more as mechanical advantage of the engine over the vehicle goes down and that more 'slipping' makes the stall feel higher.
also as more slippage occurs,more heat is generated,so a 3500 stall w/2.73s would require a 'bigger,more efficient' fluid cooler than a 3500 stall w/3.73s' would.
a 3500 stall is a good choice for 2.73s',most recommend in the range of 3500-4000.
as far as tuning,every vehicle is different,some need tuning,some don't.
I have the Yank SS4000 with 3.42 gears, full exhaust/lid, 3710lbs, goes 12.30's and drives perfect. Stock trans with 112K miles. I was going to go with a 3600, but glad my friends talked me out of it. I love the big stall. I actually did have it with a 2.73 gear for a few months, went 12.4's with that gear, but driving around town took it too much to get going, thus why I put a 3.42 gear in it. Just for reference, before the stall it went 13.4's. IMO, if your spending that kind of money, go big or go home. but that's just me.
One other suggestion, if your not lowered, get a deep aluminum pan with fins. On my 3'rd set of drag radials, I think my 25th or 26th bottle of nitrous and still the same 4L60E trans it rolled off of the assembly line with.
Oh, and untill last January I was runing 2.73's.
If your trannys in decent shape you will have no problems with a stall.
And if you stay with a 3000-3200 your stock tune should be just fine.
pm me if I can be of any further help.
Chris
