broken driveshaft and destroyed trans...
and te second pull...bammm, the driveshaft went out and craked the bell housing and case.
from the looks of it my rearu-joint split completely in half, I was told that my u joint couldnt handle the power cause it had the grease fitting which weaken the u-joint...
one expensive and upsetting night lol
As for the u-joints most of the "high performance" joints don't come with grease fittings anymore because the "grease fittings make it weaker" theory.
Im looking to do an all out th400 this time with all proper stuff to handle the power, with ultrabell and aluminum drum..
Maybe a couple sponsers can quote some prices lol
BTW the rear pinion was the first to let go im sure because of the grease passages cause it completly split so you can see the entire grease passage on both halves of the broken pieces
Check:
1) Pinion angle
2) Angle of the drivetrain
3) Use a heavy duty high speed balanced driveshaft
4) If possible strap the car down by the axle tube or something besides the body (pulling it down loads the suspension and rotates the pinion even more
I seriously doubt the Ujoint was the first failure point. Even when mine broke the u joint survived...the rear yolk was ruined but the u joint was still in it. I would use solids in the future though.
Mine was a bad combination of trans angled down too much and a cut/spliced factory steel shaft (look up "critical speed") that was too long for the RPM I was turning.
So now im a little lost on what may be the cause of this disaster, I will post some pics today that I took...
But my setup is a front motorplate with no midplate, ironblock 370, th400, yank converter, stock trans mount, bmr th400 trans crossmember w/ T/A relocation, steel 3" driveshaftmoser 12bolt with upgraded yoke
Im just hoping it didnt mess up my main bearings or anything engine related
My steel shaft broke last week while doing a steady 80mph.....we"re all stumped as to what failed first too. Wierd ****...
Sorry to hear your tranny got hammered.....I got lucky and it was fine, good thing to because it was completely rebuilt 2 weeks before this shaft failure.
with pics of what was left...........
https://ls1tech.com/forums/gears-axl...ing-80mph.html
I seen the flexplate cracked as well and either the converter bolt is loose or it pulled the thread outta the converter because I can see threads between the converter and flexplate
I know for sure there was a vibration right before it happened
What TQ-Arm mount do you have........thats enough pressue at high rpm to put energy into the tailshaft housing and case, via the TQ-Arm, to break it. When my shaft broke the front 3 feet of the shaft fell out of the car, only that rear 18" piece remained attached to my rear-end. So the TQ-Arm is the only thing that had contact with the tailshaft housing to put any kind of force on it.....
