Have a 4L60E question
Old Oct 22, 2010 | 07:59 PM
a05c's Avatar
Default Have a 4L60E question
for a 4L60E, that's had a fresh rebuild (unsure on mileage) with no issues arising.
shifts great, fluid looks and smells great.
my big question is, on a turbo app... stock LS1 in front of it, stock converter also, with a small 66mm
is there anything I can do to preserve the trans and keep it from burning up a trans.
car makes ~400 on 5psi.. not planning on turning it up for a long time or doing anything becides driving the car.
Thanks,
Andrew
Old Oct 22, 2010 | 09:42 PM
garygnu's Avatar
big tranny cooler and a deep pan,change the fluid every 5000 miles.
Old Oct 23, 2010 | 03:43 PM
a05c's Avatar
it has a stock pan on it. and dont know for sure when it was gone through.. or whats inside. I was told that it's a stock rebuild, when the car was tuned the tuner definatley went and changed the trans tables.
Old Oct 25, 2010 | 10:18 AM
Jeremy@RPMTransmissions's Avatar
Heat is the mortal enemy of all automatic transmissions. The best thing you can do to make it last as long as possible is use a really nice bar and plate style cooler. The largest one you can fit without causing any packaging issues. I deep pan will definitely help by increasing fluid capacity.
Old Oct 25, 2010 | 07:14 PM
dlk1950's Avatar
^ x2 but I like big cooler with fan, My car sees a lot of track time.
Old Oct 26, 2010 | 05:16 AM
PBA's Avatar
PBA
The stock LS1 torque converter is very hard on the gear train with more horsepower. They are big and very heavy. A good 9.5" lockup will take about 30 - 35 pounds off the back of the crankshaft here, which will give you a longer transmission life, besides much added performance. The "modified" version of the TransGo Performance Shift kit will help here too.
