trans cooler info
My first part of the test was running with the factor cooler only as a baseline. I averaged 165deg with a hi of 170deg and low of 160deg over a 5mile drive with both hi-way and city driving. The next part was running both the factor and external cooler, during the same drive I averaged 150deg with a high of 160deg and low of 140deg. Next I bypassed the factory cooler and averaged just about the same temps. On the last test I added a external filter b4 the cooler and again the same temps. Engine temps were averaged at 165deg with outside temps in the mid 50's. Veh runs a 2800 stall
I think you should try driving longer than 5 miles.
Does your car typicaly run 165f average all the time? If it does its not good. None of these engines should be running below 190f.
