Broke my second 300m shaft
Old Oct 28, 2010 | 09:49 PM
davidsnet's Avatar
Default Broke my second 300m shaft
I have now broke my second 300m billet shaft in my 4l80. The setup Is a 427 TT, circle d 5 discs lockup converter,4l80 with Tci manual valve-body with trans brake. The first shaft broke on a 3 to 4 shift blowing the tires off on the street. The next shaft broke in front of my house on the trans brake @4000rpm's.... I have been buying the shafts from patc transmission and at $400 bucks it's getting kinda expensive...... Any thoughts ?
Old Oct 28, 2010 | 11:45 PM
Daryn's Avatar
Formerly darynC-10/23/10
maybe get them cryo'ed too? not sure if it will be any better
Old Oct 29, 2010 | 09:49 AM
slow67's Avatar
Gingervitis Addict
Pic of where its broken?
May want to try a different manufacture's input, as at least 1 4L80Es have seen 7's.
Old Oct 29, 2010 | 10:01 AM
davidsnet's Avatar
Old Oct 29, 2010 | 01:47 PM
Daryn's Avatar
send it back to them and ask for a warranty?
Old Oct 31, 2010 | 04:07 PM
jakeshoe's Avatar
PATC is getting that shaft from CKPerformance.
If they won't warranty it call Chris, he may.
Jake
Old Oct 31, 2010 | 09:26 PM
FLT's Avatar
FLT
I hate to say this but that shaft looks like a factory shaft. Can you take a picture of the front of the shaft that goes into the converter? I want to see the area where the hole is on the end of the shaft. Also do you have your TCC applied when you are shifting? I have seen this break shafts in the past. Just a thought. Vince
Edit.....Also take a pic of the end that broke where either there is a set screw or check ball installed. This will be the end that is installed in the forward drum.
Old Oct 31, 2010 | 09:41 PM
jakeshoe's Avatar
Vince,
You are probably correct,
all the billet shafts I've seen have a set screw in the rear hole.
The ones I use look totally polished, CKs look similar to stock and PATC uses/sells CK parts.
Did you ever get a chance to test the transbrake?
I've got new 4L80E seperator plates made as well.
Old Oct 31, 2010 | 10:17 PM
FLT's Avatar
FLT
Good point Jake. I did edit my above post to get pic's of both ends!
As for the brake no I have not had a chance yet. Just need to get caught up so I can spend some time to test it against the "other". The one issue IMO is the low starting position that we discussed a while back. I did see the plates on the bullet!
Old Nov 1, 2010 | 06:34 PM
kevin87turbot's Avatar
You might try TCI's new 300M input shaft. It sounds like you have a pretty nasty hot rod!
