true or false?
Old Nov 12, 2010 | 10:00 PM
dgcustomz's Avatar
Default true or false?
Can you use any 4l60e 93->up on a 5.3L ? I am asking about the computer being able to run it. Are the pinouts the same? As far as the tq convertor spacer goes that is not the issue.
I have an 01 5.3L with the stock harness already cut and modified for a standalone and I am looking for a 4l60e. I heard that any 4l60e can work. True or flase?
Old Nov 13, 2010 | 10:20 AM
Jays_SSZ28's Avatar
False.
Old Nov 13, 2010 | 04:16 PM
dgcustomz's Avatar
Originally Posted by Jays_SSZ28
False.
Would you care to elaborate? What do you know about the reason as to why it will not work. Or is this a guess? I need someone who has personal experience. Thanks guys.
Old Nov 13, 2010 | 05:59 PM
Jays_SSZ28's Avatar
Get one thats '97 and up non LS1 type. '93 to '96 will work with some wiring modifications.
No idea what you mean by you have your wiring harness cut up for a stand alone.
Old Nov 13, 2010 | 07:17 PM
dgcustomz's Avatar
Have you never heard of a standalone wiring harness? You take a stock harness and cut and modify it to run on only the things necessary to run the engine.
ex. I removed the rear o2's, removed the egr harness, removed the park/neutral safety switch harness, etc etc etc.
I have 2 relays and 4 fuses running the standalone harness. I will try and get more info on the transmission interchangeability.
Old Nov 13, 2010 | 08:03 PM
Jays_SSZ28's Avatar
I have. Just not sure what it has to do with the transmission. If you want to run a 4L60E then you obviously have the transmission harness still.
If you want to rewire an older 4L60E you can, there are just more differences between '93 and '97. It would be easier to just get one close to the year of the rest of your stuff.
Old Nov 13, 2010 | 08:42 PM
dgcustomz's Avatar
It has alot to do with it... I thought it was obvious that I posted that I was looking for a 4l60e to work with a stock 01 5.3L harness that I had modified to be standalone. I can't run a 4l60e without a harness and computer. soooooo
Old Nov 13, 2010 | 09:12 PM
Jays_SSZ28's Avatar
Ok now it's a stand alone harness to run just the transmission.
I read
as in you have a 5.3 that your looking to put a 4L60E onto and you already have the converter to engine part figured out.
Guess you left harness and computer out of that sentence. I only know what you tell me.
Old Nov 13, 2010 | 09:34 PM
dgcustomz's Avatar
lol.. ok bud, I have this same thread on other sections and you are the only one that has trouble understanding it. Thanks for your info so far and Next time I will try and break it down so the reading impaired will understand.
Old Nov 13, 2010 | 10:27 PM
Jays_SSZ28's Avatar
Maybe you should learn how to explain what the **** you're butchering.
Says using a 4L60E with a 5.3, not just the harness.
I have an 01 5.3L
Again you say you have a 5.3.
Here I'll rewrite it for you so it makes sense.
Can you use any 4l60e 93->up with a 5.3L computer and harness cut and modified for a standalone? I heard that any 4l60e can work.
Too easy I guess.
Old Nov 13, 2010 | 10:38 PM
dgcustomz's Avatar
Too easy I guess.
This is everything from my first post....
I guess you fall in the reading impaired section.
Why is it that you are the only one that has an issue with it? Do a search on my other threads about this same topic, all I did was cut and paste it. Everyone else clearly understood but you. I had an attitude towards you from you first post by just saying "false". With no explanation what so ever. Alot of people and it looks like including you, jump to post and don't read the thread before posting. If you didn't understand the thread why comment. Or you did understand and chose to become a keyboard cop because it wasn't to your standards. Like i said above.. thanks for your information so far as I need no more of your help. As for everyone else, Thanks for understanding the thread and not making an issue of it. The majority of everyone has agreed that 99 and up is the model that will need to be used when running a harness of my year model.
Old Nov 13, 2010 | 10:40 PM
Jays_SSZ28's Avatar
You're right, they do all understand
I know about the spacer for the tq convertor and that is not my question. I have posted this in different section and everyone agrees that it is false. I am not going to use a 700r4 and I never asked for that option, my question was never about a 700r4 nor about what transmission I can run. I am looking for a 4L60e, looks like I will just find a 3 piece 4l60e.
Originally Posted by sierrac3_s2000
To run it off the LS PCM you will need the newer style 4L60E that has PWM stamped inside the bellhousing behind the torque converter.
Which, without guessing, would be a '97 to '03 as I said earlier in this thread.
Originally Posted by jomomma
i think that is a true statement. i bet if you ask this question in the transmission section you'd get a definet answer!
And my definate answer was '97 to '03.
https://ls1tech.com/forums/conversio...rue-false.html
Originally Posted by v8sten
99 thru (i believe) 03 trucks use a 4l60e in them. i just got done stabbing one in my friends 02 gmc sierra
Check the timestamp, thats what I said earlier.
Old Nov 13, 2010 | 10:44 PM
Jays_SSZ28's Avatar
Just get over the fact that I questioned your hacked up harness. Thats what you have a problem with. I said what years work with a '99 5.3 pcm regardless of what the hell you're doing with it. Thats the answer, you're just upset that I questioned it.
Old Nov 13, 2010 | 10:53 PM
dgcustomz's Avatar
So you did understand!
Why are you making it harder than it needs to be! I have thanked you for your information and by you adding this you have me believing that you did understand and chose to be the internet jockey. Like I said, I had an attitude because of your no information first post. You then began to add information and question what a standalone harness is. Then said that you know what it is but you didn't know what it had to do with the transmission and then you go to say that I didn't put harness and computer in the first post. That's just contradicting by saying what does the harness have to do with it but then say that the harness info is needed. The guy who told me to come to the transmission section only giuded me this way because he didn't know the definite answer. I am thanking you again and no need for you to reply anymore. I have my answers thanks to everyone who clearly understood.
Old Nov 13, 2010 | 10:56 PM
dgcustomz's Avatar
questioned my hacked up harness? I have no issue with you asking me about my hacked up harness as you put it. You are steering another direction now. I hope you are blowing off steam or something becasue I hope this isn;t your regular routine. Life would suck to be angry all the time. Pick on the little guys do you.... internet tough guy?
Old Nov 13, 2010 | 10:59 PM
Jays_SSZ28's Avatar
What the hell just happened lol.
Good luck with your project.
Old Nov 13, 2010 | 11:01 PM
dgcustomz's Avatar
Thank you sir! lol!
Old Nov 13, 2010 | 11:02 PM
Jays_SSZ28's Avatar
I hope you are blowing off steam or something ?
Yea, you call me reading impaired. Now look through all your other threads I was the first to answer your question.
Old Nov 13, 2010 | 11:08 PM
dgcustomz's Avatar
here we go again.... your first post was "false" with no info. I had to question it. We are here to LEARN! Information is the key. You gave me a word. after I questioned you, then I got more info. If I hadn't questioned you then you wouldn't have answered my question. true or false?
Old Nov 14, 2010 | 11:20 AM
Jays_SSZ28's Avatar
True!
