Manual Valve Body Driveability
Old Nov 15, 2010 | 11:47 PM
TrippyJoey's Avatar
Default Manual Valve Body Driveability
I'm planning on getting a local shop build me a 4L80E with manual valve body for my street/strip project next month. Driveability isn't a big concern for me but I want to know what to expect from a manual valvebody especially when slowing down or downshifting.
Old Nov 16, 2010 | 10:14 AM
mwg2600's Avatar
It works like a standard if the shifter is in 4th you in 4th, if you pull it down into 2ed your now in 2ed. Is that what you wanted to know?
Old Nov 16, 2010 | 11:58 AM
SuperSlow02's Avatar
I don't know how it will be with that trans, but usually you will want to come to a complete stop before downshifting. It's a slight pain, but not too bad
Old Nov 16, 2010 | 12:45 PM
mwg2600's Avatar
Buddy of mine has a 4l80 w/ manual valve body in his car. You can downshift it from any speed. He drives it on the street more than at the track.
Old Nov 16, 2010 | 01:31 PM
TrippyJoey's Avatar
This ^^
I've heard some advice like this, since autos down have a clutch downshifting is a little tricky especially if you are off the throttle like slowing down at a stoplight.
Old Nov 16, 2010 | 01:37 PM
Mguncowboy's Avatar
You just drive it like a standard minus the clutch. Down shifts are not an issue. Buy a good ratchet shifter and thrash through the gears at will.
Old Nov 16, 2010 | 04:01 PM
Photochop's Avatar
My take on it is the 3rd reply down in this thread...
https://ls1tech.com/forums/automatic...ivability.html
Old Nov 16, 2010 | 04:45 PM
Jays_SSZ28's Avatar
Which is this:
Originally Posted by Baynut
Is that part on the trans then? and where would you source the vacum?
Thanks.
Old Nov 16, 2010 | 04:48 PM
Jays_SSZ28's Avatar
You upshift and downshift with the shift lever in a manner that is close to the same transmission shifting automatically. It's not rocket science.
Old Nov 16, 2010 | 06:39 PM
This ^^
As long as your on the throttle it fine. Again that's the way it is with my 400.
Old Nov 16, 2010 | 06:53 PM
TrippyJoey's Avatar
Thanks this is what I was mostly wondering.
Alright the Thread is done now my concerns have been answered.
