2001 4l60e IS THIS POSSIBLE
Old Nov 17, 2010 | 01:41 PM
dragracing91lx's Avatar
Default 2001 4l60e IS THIS POSSIBLE
is there any way to disable the shifting solenoids that run the 1st and 4th shifting i want to sit my car up to leave the starting line in 2nd and shift into 3rd by the finishline 1/8 mile....thats all i do is bracket race the car 3600 convertor looking to benefit on a marginal track with no tire spin but still have all my mph
thought maybe you could put a toggle in the circuit and mount it under the hood and activate it when i get to the track then flip it back for the drive home any ideas what wires etc? the car runs 7.60s at 90ish with 1.60 60ft my goal is 8.20s at 90ish with a slow 60 ft
Old Nov 17, 2010 | 01:46 PM
slayer performance's Avatar
if you manually select 2nd it should take of in second.
Old Nov 17, 2010 | 02:11 PM
Kevin01Z28's Avatar
Yea just put it in second. Not sure how much your tranny is going to like full throttle take offs in second
Old Nov 17, 2010 | 09:11 PM
if i do that it will stay in 2nd. if the solenoids wont activate i could leave the selector in 3rd and it would start in 2nd and automatically shift to 3rd
Old Nov 17, 2010 | 10:15 PM
Jays_SSZ28's Avatar
Start in second, right after you launch push the shifter to third. This way it'll stay in second even after you moved the shifter but still shift to 3rd at it's normal automatic shift point.
Old Nov 18, 2010 | 09:36 AM
id always heard from a reputable transmission guy in the area that it wont hurt the tranny launching in 2nd if you dont run the car back to back and monitor the trans. temp
Old Nov 18, 2010 | 07:06 PM
good luck with that!
Old Nov 19, 2010 | 02:04 PM
11seccamaro's Avatar
I second that..... def think you will be having some major issues very very soon. if you want a slower time dont launch as hard in first.... learn your car and maybe lift a little near the end
Old Nov 19, 2010 | 06:13 PM
ws6fitz's Avatar
I bracket race my car often. Launch the hell out of that thing and cut a good light. Thats all bracket racing is anyways, getting the better light. Then when you take a nose on the guy ease off the gas. Yes, it is that easy.
Old Nov 26, 2010 | 01:47 PM
i know how to bracket race..actually been very successful at it..and i know my car...the whole point im trying to make is i want a slow lauch im using a delay box so hitting the tree is not a problem..i want a slow launch with a slow et with big mph
