corvette to f-body
Old Nov 17, 2010 | 04:01 PM
ctsls6's Avatar
Default corvette to f-body
is it possiable to fit a 2001 4l60e from a corvette to a 99 transam. what i need to make this work
Old Nov 17, 2010 | 04:45 PM
Predator T/A's Avatar
no the cases are completely differnt disign since the trans is rear mount and mounts to the diff. not only that the vette uses the lt1 style converter so to use your converetr you would also have t ochange the pump and the input shaft. its just really not doable due to the case design of the trans. the out put shafts is shorter also. and you wouldnt be able to put a tailshaft hpouysing on the vette trans
Old Nov 17, 2010 | 04:47 PM
chaman's Avatar
Interesting. I would have thought they be the same.
