4l60e interchangeability question
Old Nov 30, 2010 | 09:26 AM
jason abernathy's Avatar
Default 4l60e interchangeability question
does anybody know if a 2000 z28 4l60e tranny will work with and plug in to the wiring harness from a 2002 chevy 2 wheel drive pickup with a 5.3 and will the computer operate it fine,if not what has to be done,also i assume the 5.3 bolts up and is completaly compateble so far havnt found a simple answer anywhere or i just didnt look in the wright place, thanks for any info
Old Dec 1, 2010 | 08:18 AM
Vince B's Avatar
Moderator
Yes it will work. The differences between the two units will be the shifter linkage shaft, tail housing, and also if installing into a truck you will need to swap the pressed on sleeve to seal a vented yoke. There are a couple of other differences internally but it will work. If you are installing the fbody trans into a truck i would not worry about them. If you are going the other way then I would probably consider installing the second gear band servo from the fbody unit into the truck unit. I hope this helps. Vince
Old Dec 1, 2010 | 10:38 AM
Default 4l60e interchangability question
thanks for the answer ,its nice to finally know
