4l80 Trans brakes/mvb ??
The HD3 kit is full manual.
With our full manual setup, it is plug and play reversible to PCM control.
Using a computer, you can still manually shift the 4L80E.
If you use a manual VB it must always be manually shifted.
Can I have best of both worlds, i.e. tranny staying in gear when I need it (I would hate it to change the gear when I'm taking corner sideways on wet road), and fast changing gears during dragrace or just good start from the lights?
Could you please explain that a bit?
If you put the shifter in 3rd, there is physically no oil to go to 4th, so the trans will still go 1-2-3 autmoatically.
the 2000 car 4L60E tune has "2nd gear start", so if I put the shifter in 2nd, it will stay in 2nd ALL the time.
If I put the shifter in 1st (well, at as long as I don't downshift to 1st about 30 something mph) it will always stay in 1st.
Its about as good as you can get as far as best of both worlds.
And if I opt for manual valve body, if I select 2nd gear it won't change anywhere and stay in 2nd forever?
My friends truck (very early 99 GMC with 4.8L PCM) will shift 1-2 even if the shifter is in 1st. But EFILive can correct this (currently hptuners tuned).
Correct. The gear the shifter is in is the gear that the transmission will be in.....forever.
