4L60E Problem
Old Dec 9, 2010 | 08:53 PM
CrumZ28's Avatar
Default 4L60E Problem
I have a LS1 Camaro with 4L60E and last week my o2 sensor wires shorted out on my header. I changed the wires and checked the fuses. The same day my transmission won't shift past 2nd, I still have reverse. The brake lights stayed on for a while. I read that the transmission is tied into the brake fuse. I've disconnected the battery to reset the PCM and still didnt work. Help...
Old Dec 9, 2010 | 09:11 PM
kcs02ta's Avatar
it could be stuck in some sort of a limp mode?
Old Dec 10, 2010 | 03:14 PM
CrumZ28's Avatar
how do i fix that, spoke with gm and they said to disconnect battery to reset pcm, that didnt work. cud i have shorted out the pcm when the o2 sensor shorted?
Old Dec 10, 2010 | 04:49 PM
cody161's Avatar
I'm not sure if Fbody's have this but try resetting the TAPS using a Tech 2 scanner. I'm not sure if aftermarket scanners will do it or not.
Old Dec 10, 2010 | 04:58 PM
Jays_SSZ28's Avatar
Check the fuses again.
Old Dec 11, 2010 | 08:26 AM
Vince B's Avatar
Moderator
When you say it will not shift past 2nd are you manually shifting this trans or is this in the OD or D range? I agree with Jay that you should check your fuses. Normally a condition with no power to the trans is a 3rd gear start not second. This can easily be confused. Vince
