jake brake install questions
Here's the link to the instructions
http://www.jakesperformance.com/4L80...struction.html
in your case plug both of the holes near the rear servo. You have the old plate that requires plugging both holes, our new plates only require plugging one.
You need to slot the pin, so that oil can have an escape path from the backside of the servo to the case internals. Don't grind off the end of the apply pin on a working unit.
