swapping to a 4l80e
Old Dec 20, 2010 | 03:45 AM
donedidit's Avatar
Talking swapping to a 4l80e
I did a search and couldn't find anything, I'm going to swap out my 4l60 to a 4l80 and i want to find some pics of where you have to pound out the trans tunnel.
any other info or advice on doing the swap would be cool
Old Dec 20, 2010 | 05:08 AM
Vince B's Avatar
Moderator
Take a look at the top of the main page of this section in the stickies. There is a bunch of info in there that will help you. Vince
Old Dec 20, 2010 | 11:49 AM
donedidit's Avatar
Ya saw the stickys but there was no pics showing where you need to bang out the trans tunnel
Old Dec 21, 2010 | 01:59 PM
slow67's Avatar
Gingervitis Addict
Its the brace that runs across the transmission tunnel. It runs into the connector for the transmission. If you run a late style (97 up) 80e, you may need to trim the other side for the rear cooler line.
Old Dec 22, 2010 | 01:56 AM
donedidit's Avatar
anchance for pics, for a 97+ 4l80e
Old Dec 22, 2010 | 10:48 AM
slow67's Avatar
Gingervitis Addict
I can next time my car is on the lift, but it may be a week or 2 (going out of town week after christmas).
Old May 12, 2011 | 11:25 PM
dutinsss's Avatar
bringing back an older thread but what part of the trans needs to be grinded off? i ground off what i thought where the "ears"(2 tabs on each side toward the front of the trans) but it looks like part of the trans that the dust cover bolts to needs to be ground off as well. it's hard to explain, but it's a part of the trans on each side that has the bolt holes for the first bolt on each side for the dust cover on it.
Old May 12, 2011 | 11:46 PM
slow67's Avatar
Gingervitis Addict
doubtful, the dust cover bolts on with 4 on the bottom of the bellhousing, right by the converter. The ears that need to be cutoff usually only need to be cutoff because of headers.
Old May 13, 2011 | 01:28 PM
dutinsss's Avatar
ok, i'm just trying to make sure i understand which are the "ears" before i start grinding. i'll try to post a picture up.
Old May 13, 2011 | 01:44 PM
dutinsss's Avatar
I know these pictures suck, but all i have on me is my phone. but is that piece circled in yellow what needs to be ground off? it's the piece of metal that sticks out on both sides and has a bolt hole in it for something, i'm assuming the dust cover.
Old May 13, 2011 | 02:59 PM
Powershift_98's Avatar
I just finished my 4l80e swap as well, I have 1 7/8" American Racing headers and had to cut off the passenger side top dust cover hole. I'll upload a picture shortly... This is an earlier model trans.
Couldnt find a picture after making the cut but I added a line showing you about how much I needed to clear the headers. Ill be under the car within a week and can get a finished pic if you'd like.
Old May 13, 2011 | 08:38 PM
slow67's Avatar
Gingervitis Addict
Go ahead and cut like Powershift_98. That's fine.
Old May 13, 2011 | 11:24 PM
dutinsss's Avatar
ok that helps a lot. i just wanted to be sure before i started cutting away at this thing. thanks a lot guys.
