convert 4l60e to 4l65e
Old Feb 8, 2004 | 06:58 PM
fast2001's Avatar
Default convert 4l60e to 4l65e
Has anyone ever done this yet. What is involved to convert your 4l60e to a 4l65e. any comments.
Old Feb 8, 2004 | 07:57 PM
2001 Pewter WS6's Avatar
Restricted User
I believe it is a direct replacement. Others may want to chime in...
Old Feb 8, 2004 | 08:11 PM
maddboost's Avatar
FLP sells a built 4L65E that they refer as their LEVEL 5 tranny.
Heres from their website.
4L65E level 5 transmission - Includes GM 5 pinion planet assemblies front and rear, 4L65E reaction shaft w/bearing, FLP extreme duty sun shell w/bearing, and cryogenic treated input & output and reaction shafts. Also includes GM deep pan with drain plug.FLP extreme duty input housing with steel sleeve pressed around input shaft splines with machined overun piston to increase strength.
Old Feb 8, 2004 | 10:32 PM
M_Minnick's Avatar
It was a relatively painless swap for me. The only major(if you could call it that) mod was to swap out the shift selector shaft, as the one included with the 4L65E will hit the trans tunnel. Other than that, it is pretty much a direct swap. We had it out and apart a couple months after the swap due to the input splines stripping on my TCI SSF3800. There was no damage to the tranny, but the differences between it and a 4L60E were readily apparent with all the parts spread out on the bench. I am hoping this tranny will last me a while.
Old Feb 9, 2004 | 11:48 AM
fast2001's Avatar
where did you buy your 4l65e transmission. The FLP 4l65e is a little out of my price.
Old Feb 10, 2004 | 12:15 AM
DeepBlueZ's Avatar
i converted to a brand new GM 4L65E.
Shift selector shaft must be changed as stated and tailhousing had to be swapped with a 4L60E tailhousing so as the torque arm could bolt up. a total of 15 minutes worth of modification for F-body use. If this is for your truck, i dont believe theres any modification at all. you just need to order the truck version of the trans and not the GMPP/Holden car version.
Old Feb 10, 2004 | 08:29 AM
TTPMatt's Avatar
We build 4L60E's to the 4L65E in our race build units. They run at $1950 for your core rebuild. This unit will handle 700bhp no problem. Our tranny builder has one of these in a 9.4 second Vette.
Let me know, we are under retail price for the tranny.
Includes a 1 year/12,000 mile limited warranty.
516-779-2330
- Matt Sorian
