Best Stall to match up with TSP 228R cam?
Just wondering what to go with. Probably going with a Vigilante since I have had good success with them. Only ones I've had from them are 2800 stall speed. Should i go Higher? Our local speed limits here are very low, and I don't want to run it too hot because the converter is too loose.
Set-Up:
Heads/Cam/Spray.
Expecting over 550rwhp.
3.42 gears in it.
What do you think?
Set-Up:
Heads/Cam/Spray.
3.42 gears in it.
What do you think?
if i am not mistaken, most converter manufacturers usually offer a free restall, so you could always step it up if you went too small the first time. it is a pita to have to drop the tranny again, but it is usually an option. harldy ever do you see people going to a smaller stall, but some do, but even in this thread some are considering stepping up. 3600 would prob be a good start.
We have run a TON of Vigilante and Yank converters. Both are extremely nice and haven't had a problem with either. Both offer a free restall as well. The Yanks do tend to be a little tighter and are a little cheaper on the lower stall speed converters. I wouldn't hesitate to put either in one of my cars.
Jon
Jon
