question about overheating transmission
the pressure is up high enough right now that if i drop the car in reverse it will chirp the tires about 50% of the time so i was just seein what everyone thinks info would be great thanks
Line pressure high enough to chirp reverse can cause it to run hot at idle.
High idle speed will cause it to run hot and chirp reverse.
People need to learn that these transmissions don't need over 240 PSI at WOT, and thats even on the high side. These need to be tuned only for higher shift pressure and higher tcc apply pressure when needed. The constant pressure table should never be tuned much let alone high enough to chirp reverse.
the car idles at about a 1000 rpm i am pulling the computer back out and i am gonna get it retuned to idle at about 850 and i wanted the line pressure backed off. I am not sure what kind of pressure the tranny is putting out right now but it over heats at an idle when you go down the road it is fine..
The conver is all stock the tranny is'nt much over stock the fluid runs through just the hayden and not the stock and hayden is in front of the radiator where it belongs.
so do you guys think i should drop the idle and the line pressure??
No one seems to realize you can increase just shift pressure on the upshift pressure modifier table. And base shift pressure table.
If the constant pressure table needs to be messed with, it's either to fix a weak transmission, inexperienced tuning, etc.
And about the idle, yea 1000 is high considering stock is 550 hot. Thats why I asked.
