4L80e standalone help
Old Jan 28, 2011 | 12:12 PM
3.8redbird's Avatar
Default 4L80e standalone help
Looking at my choices I have decided to save $250 in the long run and just get a 4L80e now instead of rebuilding a 700r4 and switching later.
So which standalone for a 97 4L80e behind a SLOW (300chp) 350?
I have found:
TCI Auto 302820
Painless 66501
both of which I like.
Any reviews or other recommendations are welcome.
I am using a quiksilver B&M shifter either way
Old Jan 28, 2011 | 12:29 PM
slow67's Avatar
Gingervitis Addict
The Baumann controller is out there as well.
If you are are on an extreme budget you could build a megashift GPIO (~$250ish).
Old Jan 28, 2011 | 12:43 PM
3.8redbird's Avatar
Id rather not build my own. Just to be safe.
Baumann is $590 with wiring harness. Any reviews?
Old Jan 28, 2011 | 01:07 PM
slow67's Avatar
Gingervitis Addict
Probably not on here since 99% or more use the stock PCM. They are mostly used in older carbed vehicles (also it has been very popular with the Ford crowd).
Jake's Performance is also a dealer for them.
Old Jan 28, 2011 | 01:13 PM
3.8redbird's Avatar
Jakes is who I was going to build the trans through. Will give them a call next week.
Thanks for all the help
Old Jan 29, 2011 | 08:07 AM
forcd ind's Avatar
i used the Compushift controller, mainly because i am computer stupid, and didnt want to have to set it up with a laptop
its a little pricey, but when you buy the extras for the other controllers, like throttle postion switch (which comes with the Compushift) its not that far off
the display screen(you can get it w/o, but worth the extra), which i mounted on my shifter, has a trans temp, speedometer, tach, etc
i would buy another in a heartbeat, simple to adjust, lots of adjustment-i raced mine quite a bit, you can use a man. mode, auto, upshift rpm, etc
i had an early TCI unit, i was totally lost with it
Old Jan 29, 2011 | 12:57 PM
Jake's Performance's Avatar
The Baumann Optishift includes a basic screen, doesn't require a laptop, is one of the easiest to tne IMO, and on a LS engine there is already a TPS, approx $100 otherwise.
Still WAY less expensive than a Compushift.
Old Jan 29, 2011 | 01:05 PM
3.8redbird's Avatar
Im the one who sent you the email yesterday. Picked up the trans today. $250 for a 08 rebuild with Tq converter.
Do you also sell the TPS?
this is going on a gen 1 350 carbed
Old Jan 29, 2011 | 01:29 PM
CHAMRA1's Avatar
Whats the optishift sell for ?
Will it work on a 2004 gto ?
Old Jan 29, 2011 | 01:40 PM
3.8redbird's Avatar
Yes it should and its $600 but is on backorder for 3 weeks is what I was told.
Old Jan 30, 2011 | 03:24 AM
CHAMRA1's Avatar
Does that include the wirring loom ?
