throw your stock flexplate in the fucking trash!!!!!
Old 01-28-2011, 07:28 PM
rumblebox's Avatar
Default throw your stock flexplate in the ******* trash!!!!!
this happened at 6800rpms.
Old 01-28-2011, 07:36 PM
meine96ws6's Avatar
wow, that looks like it ripped through everything!!
Old 01-28-2011, 07:38 PM
repo's Avatar
ouch!
Old 01-28-2011, 07:40 PM
Badazz 97 TA's Avatar
damn, that had to be pretty scary. Did you buy new underwear?
Old 01-28-2011, 07:43 PM
yelo04goat's Avatar
cant see the pic but im sure it wasnt good...
i had a slight rattle when i would start my car after a night of n2o passes... 6months later and not figuring out what happen i nailed it on the highway. and thats when she let go..3000rpm or so.... cracked all the way too the teeth and took the starter with it... i probably should of looked into the noise more but i didnt...
now have a nice TCI waiting on me to finish the motor
Old 01-28-2011, 07:44 PM
joe77's Avatar
good thing your not injured id hate to see that come through the floor and slice your leg or foot. I had the flexplate almost brake in a complete circle, it had cracked like 320 degrees, luckily it gave me enough warning that i could get it fixed.
Old 01-28-2011, 08:40 PM
FastKat's Avatar
So what exactly happened? Did the outer piece totally separate from the inner piece?
Old 01-30-2011, 01:01 AM
rumblebox's Avatar
the gear just peeled off the flexplate. every weld is broken, and there's nothing but the plate left.
thankfully i procrastinated my 4L80 swap and this happened first.
Old 01-30-2011, 07:24 AM
senicalj4579's Avatar
OMG! WOW! Thats unreal. Theres enough proof on here that its a good idea to can the stock flexplate. When the stall goes in, so will another flexplate! Wow!
Old 01-30-2011, 08:18 AM
chevymec's Avatar
Did it get the body of the car any?
Old 01-30-2011, 09:06 AM
Moderator
Vince B's Avatar
Were you having any issues with starting your car previous to this? The reason I ask is the flex plate is still in one piece however the obvious happened. I'm curious is maybe the starter or the timing of your engine might have had something to do with this. Years ago I replaced many flex plates because the ring gear would be worn out in places. I'm thinking this might be the reason for what happened here. Just a thought. Vince
Old 01-30-2011, 10:48 AM
rumblebox's Avatar
no it didnt show any signs before it let go. after the 1st weak weld let go it was a donimo effect.
Old 01-30-2011, 12:07 PM
01ssreda4's Avatar
I think the 6800 rpms had something to do with it.
Old 01-30-2011, 12:11 PM
fbodygod's Avatar
+1 on that one
Old 01-30-2011, 12:23 PM
rumblebox's Avatar
that's not even that fast
rumblebox's Avatar
yea there's a hole in my right fender and a vent missing.
Old 01-30-2011, 12:36 PM
02sleeperz28's Avatar
I just recently ordered a TCI flexplate for my car. Sorry to see this damge done to your car. Hope you get everything up and running soon.
Old 01-30-2011, 03:47 PM
FastKat's Avatar
Wow, well at least nobody got hurt.
When I think flexplate failure, I think of cracks turning into a total melt-down, where the (inner) engine part breaks away from (outer) converter part. I always thought that was the reason the aftermarket flexplates were supposedly so much stronger... not because the ring gear was welded on better, but because the plate and its mounting points were thicker and meatier.
This is a great reason to start that 4L80E swap!!
Old 01-30-2011, 07:44 PM
ZTwentyAteU's Avatar
your lucky it didnt come through the floor
Old 01-31-2011, 03:34 AM
Bobsmyuncle's Avatar
mine had 3 cracks in it, my buddys had 3 cracks, and my other buddies had broken completely in half at idle.
3 of these cars being bolt on cars making 325 hp at best.
theyre garbage.
