Are the converters swappable from a truck to Fbody?
Old Feb 12, 2004 | 10:57 AM
smokemup's Avatar
Default Are the converters swappable from a truck to Fbody?
Are the converters swappable from a truck to Fbody for the 4l60E?
Some is selling a converter used in a truck behind 5.3. Will this work behind an Fbody LS1?
I would assume yes but would like to be sure.
Old Feb 12, 2004 | 11:01 AM
quickWS6's Avatar
Yes, they will work. I imagine the less weight of the truck and the added power of the F-body would cancel each other for about the same rated stall. Which stall is it? I woulnd't use a Yank truck converter in a car because you will giving up some performance, IMO.
Old Feb 12, 2004 | 12:20 PM
smokemup's Avatar
It's a Vig 2800. Going into a stock 2002 Z28. I just got a FTRA and TSP lid but I haven't put them in yet.
Old Feb 12, 2004 | 12:25 PM
quickWS6's Avatar
A Vig should be the same as a Vig 2800 for a car. I'd go for it.
Old Feb 12, 2004 | 01:51 PM
cablebandit's Avatar
I have a Yank truck thruster 3000. I talked to Yank and he said it would work on the fbody and stall to 3200. It isn't installed yet so I can't give you any real info
