Output shaft loose? Help me out.
I was replaceing the rear seal on the tailshaft of my transmission and noticed that if you grab the output shaft itself it will move around a little bit. Is it supposed to do this? I do get some vibration that I have been wondering where it is coming from.
Yes its normal the yoke and bushing in the tail house support the shaft so it will move when yoke is out
__________________
A degree of movement is ok however if it is excessive I would suspect worn bushings or a unit that has a ton of end play. With the way I build my units there is very little wiggle here so not knowing the history of the unit I would be concerned due to the fact you have a vibration. Vince Bielanski
True if its excessive I actually had a guy several years ago with a OEM trans he had a chronic vibration since he bought the car , From apearance the trans had never been out . Well it actually did not have a case bushing in the rear at all and no sign one had ever been there car had 20000 miles on it.
__________________
It is not necessarily exesive, but I'm going to get back under the car and try to check my flywheel for cracks etc. I've heard a lot that the flywheels have been known to at least crack on stock power and I do have 135000 miles on the car. I have noticed a slight "bump" when it shifts sometimes still, mostly when not applying the gas pedal much, it doesn't seem to do that when I give it half or all out on the throttle.
