Bad Transmission Mount? (A4 trans)
Old Feb 9, 2011 | 08:17 AM
ArkBird96's Avatar
Default Bad Transmission Mount? (A4 trans)
Whenever my car is at a stop and I "stomp" it a bit, it feels like a sledgehammer hits the bottom of the car. Is that the trans mount taking a dump? Thanks!
Old Feb 9, 2011 | 08:19 AM
Jeremy@RPMTransmissions's Avatar
It could be the transmission mount or the torque arm mount. Your best bet is going to be to get the car up in the air and inspect them both. They will both feel the same, like a sledgehammer hitting you in the elbow from inside the console. haha. Good luck and keep us posted.
Old Feb 9, 2011 | 08:21 AM
ArkBird96's Avatar
How will I know if the torque arm mount is bad and is that something easily replaced?
Old Feb 9, 2011 | 09:06 AM
The mount itself can break. You will be able to see the torque arm resting against the floor board if the torque arm mount is broken. The 98+ transmission mount are quite a bit stronger than the previous unit, so I've seen more torque arm mount failures in the 98+ cars then I ever did in the 93-97 cars. That is why I mentioned the torque arm mount. If the torque arm mount looks good then turn your attention to the transmission mount.
Old Feb 9, 2011 | 11:02 AM
z99ls1's Avatar
Restricted User
Just go under the car and look to see if they are broken. It takes about 5 mins. I broke a cuple tranny mounts in my 93 z28. It sounds horrible through the shift console lol
Old Feb 11, 2011 | 04:05 PM
Mike 02T/A's Avatar
Make sure the nut going through the crossmember is there. Mine backed out or fell off, it made that same sound.
Old Feb 12, 2011 | 02:33 PM
ArkBird96's Avatar
OK. It was the biggest PITA but I replaced it with a prothane mount that I got from Summit. Not the best solution but it will work. It fixed the problem. Thanks!
Old Feb 12, 2011 | 04:31 PM
NVR_SPDS's Avatar
Sometimes if your trans mount is broken, your engine mounts may be as well. You may want to take a look at them just in case.
Old Feb 12, 2011 | 10:38 PM
ArkBird96's Avatar
@nvr_spds, thanks for the heads-up on the motor mounts. I'll keep an eye on those as well. Car has 135,000 miles on it so it might be time to replace those.
I was nervous about installing the Prothane mount given the stories about excessive NVH from the poly mount, but I kind of like the feel. It almost feels like there is an SOTP improvement, but then again, my butt dyno may need tuning . There is a slight increase in NVH, but it's really noticeable in 3rd gear when everything is turning at a 1:1 ratio. I would imagine this will lessen over time as the mount "wears in".
Old Feb 13, 2011 | 06:45 AM
01ssreda4's Avatar
Stock motor mounts + poly trans mount = bad
Poly motor mounts + any kind of trans mount = good
Old Feb 13, 2011 | 02:49 PM
ArkBird96's Avatar
Bad as in bad for the driver or the car? Will it kill my drivetrain?
