tranny mount confusion...
i blew my stock tranny mount up a long time ago...replaced it with a poly, replaced that with a 1le...
i think the 1le and the poly are taller than the stock mount (i think i might have screwed up and got a lt1 1le)...even enough to change pinion angle...
it seems now after lots of reading they discontinued the seperate mounts for the m6 and a4 and now the stock mount is the same for the m6 and a4...and it lists for $70 bucks...
with all the tailshaft housing breakage problems ive had im going to try to retreat to a stock mount to see what happens...as of now i can feel a pulsing vibration ~70 mph and i think it might be pinion angle...
anyone used a pioneer mount #622817? they sell them at oreilly's and they are on $17.99
anyone else know a large retail chain that carries something different?
ive tried autozone, napa, carquest, etc. etc...the only online site i found that had some listed for our cars was oreilly's...
it looks from what i remember just like the stocker. i remember my stocker had a gap in the middle of the mount (hollow), so it can actually twist a small amount...so does the one from oreillys. im going to throw it on soon and see if i can tell a difference.
i took some pictures...if anyone wants to host them...
this might be a good alternative to 1le's and poly's...for less than 20 bucks
BLKTA and WILWAXU i apologize for being rude, this tailshaft breakage crap just has me pissed off...
btw chromoly drive shaft? how'd that work out. Got any dyno #'s on your car. I'd love to run a 11.83, looking for tips from folks who have similar setups so my first drag event isn't a dud.
Everything runs 1/2 second faster in TX than GA right ?
no with duals ending before the rear axle...a little vibration isnt the biggest concern...the poly mount never bothered me that much...
chromoly shaft is ok...i bought it to try and cure the vibration (in my car at 70 mph there is a vibration that i cant figure out...it pulsates every second or so...its weird...feels like pinion angle or unbalanced shaft...i think im gonna break down and have a drivetrain place go over everything and see if they can figure it out...
no dynos with the cam and the current mods...im sure it would break a housing on the dyno so whats the point...
im guessing 380-385rw the way the car is now...it made 340/350 with the stock converter, stock motor, and macs
im thinking i might have gained around 40rw with the cam, longtubes, duals...
if you wanna run good times...get some et streets...especially since your stall is bigger than mine...i had to go half throttle off the line with brand new 555r's which only got me a 1.84 short time and a 12.1 et. i put on the et streets and ran the 11.83...
your 60ft will dictate your et...
good luck!
(judging by your dyno...if you car is around stock weight i think you will have plenty to run a 11). get some good tires and floor it...
