4l60E Flexplate Question
Old Feb 21, 2011 | 01:17 PM
NovaKid's Avatar
Default 4l60E Flexplate Question
Few quick questions for you guys (I've searched the net for the past hour with no success)...
I have a year 2002 4L60E and a year 2003 LS6 that I'm about to put together. I have a 168 tooth flexplate that came with my LS6 crate motor. I just mated the two and the flexplate is about 1/8 to 1/4 in from the bellhousing all the way around. Is this normal for a 168 tooth flexplate or should I go with a 153 tooth flexplate? I've noticed that summit only sells 168 tooth starters for the ls1/6. It appears the starter holes on the block are offset, which should be for a 168 tooth flexplate.
Also, is there supposed to be a thin piece of sheetmetal between the block and bellhousing to cover the open gaps?
Anyone know what's going on with this setup?
Thank you for any help!
Old Feb 21, 2011 | 10:46 PM
NovaKid's Avatar
...bump
Old Feb 22, 2011 | 04:15 AM
01ssreda4's Avatar
Can you snap some pics?
Old Feb 24, 2011 | 12:18 AM
NovaKid's Avatar
I'll definitely get back to you with those pics... I'm out of town right now. Any experience with different flexplates?
Old Feb 28, 2011 | 12:22 AM
NovaKid's Avatar
Here are some pics I found on the internet that will give a better perspective on "possibly" a piece of sheetmetal that goes between the trans and the engine block.
On mine (not pictured here), there is an open gap between the trans and block (behind the oil filter) which exposes the flywheel:
Looks like there is some kind of covering between the block and trans that's not attached to the starter:
Overall Pic:
Old Feb 28, 2011 | 12:40 AM
sjsingle1's Avatar
there are plastic covers on both sides of the block to cover those gaps at the starter and by the oil filter........had to modify the starter side on mine when i put in a starter.....will put in a new one when i pull the tranny
Old Feb 28, 2011 | 01:10 AM
NovaKid's Avatar
Oh okay, that makes sense. Thanks for the help sjsingle1!
Anyone have any input on 168 / 153 tooth flywheels? I've seen a few threads suggesting 153, but I'm still not sure if it's necessary to buy a new flexplate.
Old Mar 8, 2011 | 08:13 PM
NovaKid's Avatar
Any of you transmission geniuses have any input?
Old Mar 9, 2011 | 09:24 AM
kevin87turbot's Avatar
There is no 153 tooth flexplate for an LSx engine. They are all 168 tooth. Make sure that you have at least 1/8" (but no more than 3/16") converter to flexplate clearance once you bolt up the trans and you'll be good to go!
Old Mar 9, 2011 | 10:59 PM
NovaKid's Avatar
Awesome, Thanks for the info!
