How Much Transmission Fluid Needed?
Old Feb 16, 2004 | 08:52 AM
Brandon_TA's Avatar
Question How Much Transmission Fluid Needed?
Hey guys, either this afternoon or tomorrow afternoon, i am going to take the pan off thr transmission to tap in a sensor for a transmission temp gauge. How much fluid will I need to fill it back up properly? Also, where can i get a new filter? (Autozone?)
And last but not least, what type of transmission Fluid should i use?
thanks alot ppl.
brandon
Old Feb 16, 2004 | 10:13 AM
VoodooWS6's Avatar
The oil and filter change take 5 qts. If you are going to do a total overhaul ever, it will take about 12 qts. So, if you are just going to drop the pan, tap a sensor and change the fluid plan on using about 5 qts. However..For some reason, every time I change mine it seems to take a diffrent amount. Be cautious on just adding 5 qts..Put about 3 1/2 in, let it get hot, and top off! My owners manual says put 5 in after a pan and filter change..Mine was over filled the 2nd time! On the oil question, try and use a high grade synthetic oil. Even know it will blend with the regular trans oil, you will have some what of a synthetic blend..Plan on changing it again after 12k if you use synthetic and add synthetic again to richen the blend! Hope this helps!
Old Feb 16, 2004 | 10:29 AM
Brandon_TA's Avatar
thanks Voodoo... Good info... thanks alot!
Old Feb 17, 2004 | 11:58 AM
SuperSound99SS's Avatar
hey are u using a standard water temp gauge? if so let me know what all u had to do to get the sensor in securely
Old Feb 17, 2004 | 12:04 PM
Brandon_TA's Avatar
are you talking about my water temperature gauge, or transmission temperature?
Old Feb 17, 2004 | 12:13 PM
meant to say trans temp......im using a water temp gauge for my trans temp
Old Feb 17, 2004 | 12:41 PM
Brandon_TA's Avatar
cool, okay, ill let you know what we end up doing... probably some rubber washers on bothsides, with a nut on the back. But ill tell ya for sure.
