Best Auto Trans for 408/PT91......
Add a gearvendors overdrive if you feel you need it for highway cruising. I would guess a 3.50 or taller gear with a 28" tire depending on your shiftpoint. Even without OD, you could cruise 70 mph around 3000 rpm.
No electronics to worry about, lightweight, simple. One shift. Torque converter needs to be spot on, not kind of close.
Pics of your tow rig?? Sounds killer!
Here it is without "level" in the front. Last year when I first got the tires.
http://www.rosslertrans.com/Powerglide%20opions.htm
