Length of driveshaft for 10 bolt to th400
Old Mar 22, 2011 | 04:21 PM
Busy Mopper's Avatar
Default Length of driveshaft for 10 bolt to th400
Im getting a factory setup driveshaft cut to fit in my 31 spline th400 output shaft. but i need the dimensions for how much needs to be cut from the DS. its a short tail th400.
Old Mar 23, 2011 | 05:52 PM
Boman6760's Avatar
I used a 6in tail th350 and the stock DS. Install the trans, then measure from tail of the trans to center cap point of U-Joint on the rear. Take that measurement to a shop that can do it and they should make it from there. Mine was done in a day. Oh and be sure the rear suspension is compressed, normal ride height, or the measurement will be off. Pretty much your best way to go.
Old Mar 23, 2011 | 06:17 PM
thanks
