4L60E swap question
Old Apr 7, 2011 | 06:21 PM
92ZZ3RS's Avatar
Default 4L60E swap question
will a 4L60E out of a 97 LT1 camaro work in a 2002 camaro? thanks. dont need any of the "search" comments either. LOL. im lazy
Old Apr 8, 2011 | 08:39 AM
Jays_SSZ28's Avatar
It should work but you have to adapt the bellhousing and converter just like an old th350, th400, 700R4, etc.
The electrics should be close, seems some work and some don't. Depending on trans original application.
Old Apr 11, 2011 | 11:10 AM
supergt99's Avatar
yes it will work. 2 top bellhousing bolts dont line up. youll need a spacer on the flex plate to torque converter hub. i just did this swap the other day.
Old Apr 13, 2011 | 05:30 PM
92ZZ3RS's Avatar
thanks. i didnt know if all the connectors and electronics are the same
