What shifter to use doing M6 to 4L80E swap?
Old Jan 22, 2021 | 02:12 PM
mclasl1969's Avatar
Originally Posted by soundengineer
personally... I say go custom....
get a TCI outlaw shifter, and custom make a plate/bracket to mount your shifter to to fit how you like it to sit.
I reused the t56 center console, and just cut it to fit the shifter housing...
next plan is to fiberglass the hole shut and make it fit custom to the TCI shifter boot
Do you still have these photos available?
Old Jan 24, 2021 | 08:15 PM
5.7stroker's Avatar
I've got you covered. You need to mount the shifter about an inch closer to the engine to use the M6 plate. I haven't done it yet, but I have the M6 shift plate and intend on doing it.
https://ls1tech.com/forums/automatic...r-install.html
