4L60E puked after stall
Old Apr 14, 2011 | 06:13 PM
aothepresident's Avatar
Default 4L60E puked after stall
Edit 5/8/11:
So this is a little different than the original post, but didn't want to waste starting another thread.
Basically here is my problem now and I need help. The only thing I can think of is that trans fluid is leaking out of my new B&M cooler itself. I bought all new rubber lines (Gates 5/16" rated to 400psi) and compression clamps instead of the 3/8" cheap line and worm clamps that came with it. All connections are secure and tight. It is not leaking out of the in/out where the lines meet the cooler.
Yet, it is still leaking, definitely from the front passenger right under the radiator (where the B&M cooler is). The radiator has a wet spot of trans fluid in the basic shape of the cooler that is sitting in front of it. It is a slow leak, and will not even drip on the floor that much, but after a hard drive, you can look under and see that it has leaked. ANy ideas? HELP! Anyone have a faulty B&M out of the box? Thanks.
Old Apr 14, 2011 | 10:29 PM
Vince B's Avatar
Moderator
If its all over the engine bay I would suspect it puked out of the filler tube. Air pockets or the amount of oil would be my guess here for the source of your problem.
Old Apr 15, 2011 | 08:35 AM
That's a good possibility but it seems the area around the fill tube is pretty dry and the seal is pretty tight on it. I shouldn't have said ALL over the engine bay, it's dry on the driver's side and soaked on passenger side. How would air pockets get in there? I think I may have overfilled
Old Apr 16, 2011 | 04:51 PM
67RSCamaroVette's Avatar
Did you overtighten the fitting into the stock cooler and crack it?
Old May 8, 2011 | 04:55 PM
Bump for any help on updated original post
Old May 10, 2011 | 09:13 AM
sleepy_z's Avatar
Could it be from the previous ports in the radiator where the tranny lines were connected? The angle of the radiator coupled with hard acceleration could cause the leftover fluid to come out a little.
Old May 10, 2011 | 05:01 PM
Thanks for the response. As long as I follow you correctly, I don't think it's from the ports. I never disconnected any lines from the radiator, I just routed the aftermarket cooler into the stock plumbing. Out line from radiator > in B&M cooler > out B&M cooler > stock hard line back to trans.
Bear with me, this TC and cooler install is by far the most technical thing I've ever done.
Old May 10, 2011 | 08:47 PM
joecar's Avatar
Originally Posted by aothepresident
... The radiator has a wet spot of trans fluid in the basic shape of the cooler that is sitting in front of it. It is a slow leak, and will not even drip on the floor that much, but after a hard drive, you can look under and see that it has leaked. ANy ideas? HELP! Anyone have a faulty B&M out of the box? Thanks.
Looks like you have found it... spray it clean (remove all traces of fluid) and see if the same thing happens.
Old May 10, 2011 | 10:19 PM
I think it will be pretty difficult to remove all traces of fluid on the radiator, but basically what I'm hearing is the cooler itself must have a pinhole or something. I was hoping that wasn't the case, now I'll have to take it all off again, send it back and get a new one....
Old May 10, 2011 | 10:55 PM
jsteele90's Avatar
jack car up. clean underneath very well. start it up and sit underneath and wait until you see where it is leaking from.
Old May 10, 2011 | 10:56 PM
projectX's Avatar
yeah that does suck...
Old May 10, 2011 | 11:01 PM
I wish it was that easy. I've tried but it's impossible to see up there and it won't leak enough at idle. Even if it did, really only the residual effects are apparent when it leaks down into the trough under the radiator and then down/out to the passenger side of that trough (if that makes sense)
Old May 10, 2011 | 11:41 PM
jsteele90's Avatar
i seriously doubt you got a bad tranny cooler. double check all your connections. its also possible you may have damaged the cooler on installation
Old May 11, 2011 | 10:35 AM
joecar's Avatar
I think it will be pretty difficult to remove all traces of fluid on the radiator, ...
Spray the cooler and the radiator with brake cleaner, and let it air dry, or blow it dry with compressed air... it will be squeaky clean/dry.
Old May 12, 2011 | 07:52 PM
Ok, so I had some time to work on it today. The brake cleaner tip worked pretty well. Wiped everything down and idled the car, I even put it in gear and did some brake stands to try to get the system under more stress than just idle. Didn't get any visible leaking really, but still got minimal leaking after a short drive.
If I damaged a fin on the radiator would it cause a leak? If anywhere, the fluid seems to be coming from the bottom of the radiator/ac condenser by the passenger side very bottom corner. The only sign of the leak is when it pools up by that bottom corner.
