confused on stalls
Old Jun 23, 2011 | 09:45 PM
  #41
lemons12's Avatar
Originally Posted by 1Bad97WS-6
OK thanks what the different in 60ft between the 3600 and 4000. Everyone is telling me to get the 4K.
For a stock internal car...4000 is good for mid-high 1.5s..3600 is good for mid 1.6s. Of course this Is average, they get better and worse. there will be a .15-.2 et difference about.
Originally Posted by soundengineer
3600 My ***....
go as big as you think you can handle, and then get that size.... it will be slightly higher anyways. especially on the bottle.
Look at my signature....realize I'm about to do a lot more Juice than most people have on motor alone... and I'm already starting with a stall that hits around 5K.
and I DAILY DRIVE my car....with my big stall....
proper trans tuning will make it roll nicely thru town without needed a lot of extra RPM.
Just dont go open headers with a big stall for in town driving..LOL.... it will be really loud all the time like that.
as far as 3600 vs 4000
typically a 4k stall will be better ET in the 1/4 Mile
60' you probably wont notice a difference between the 2
personally I would get a Yank PY3600, and have dave build it as a 4000 stall...he built mine as a 4800
If you are getting a custom built converter, sure. But most buy a regular off the shelf converter. You have less chance blowing through a 3600 than a 4000 on a 150 hit.
Old Jun 23, 2011 | 09:56 PM
  #42
soundengineer's Avatar
I personally dont see the point of buying a generic off the shelf low level converter... why make your converter the weak link
if your are talking about a 3600 or 4k converter, you should go with a higher quality product that can handle the abuse you are going to throw at it...
if you are just ***** footing it around, then get an off the shelf, lower rpm converter to help with your around town gas mileage.
if you want to race it, go billet, go big, and beat on it.
and if you are going to hit it with nitrous.,.. you need to go billet anyways
Originally Posted by Men In Black 2
....pay more than a dollar......
look at everybodies entry level converters... and consider that you need to spend at least double that to get a good converter that will last and hold up to everything for racing.
this usually means you need to spend around $800 or more for a good converter...
Old Jun 23, 2011 | 11:08 PM
  #43
a-low's Avatar
Originally Posted by owentm3
If you do a cam before a stall, then you obviously wipe before you ****.
Lmao! Stall here,no cam...yet
Old Jun 24, 2011 | 10:57 AM
  #44
Kingc8r's Avatar
Would a 3800 be a good in between stall size if you plan on eventually running a 100-150 shot?
Old Jun 30, 2011 | 08:11 PM
  #45
DOUBT IT's Avatar
My TCI SSF4000 netted me a 0.6 second reduction in my ET. Biggest waste of money ever!
