where is the EPC screen
Old Feb 20, 2004 | 09:52 PM
zarnperfromance's Avatar
Default where is the EPC screen
the shift kit calls for the screen to be drilled and use a piece of wire from collapsing, does are car need these mod can't find the screeen
Old Feb 20, 2004 | 11:16 PM
Sunset01's Avatar
This is a good precautionary measure. THe epc screen is snapped into the separator plate. The body of it sits in the transmission case, I believe. You'll see when you have the separator plate out. If you are doing the transgo kit, the spring they provide doesn't really stay up in the screen- I called and they said just put it back together & it will hold in there loose (between case and valve body).
