iron headed 6.0 to th400
does it have a flywheel on it? how much does the crank stick out past the rear seal-if aprx. 3/8" past the seal, it has the longer rear crank section, just use a stock 4l80e flywheel and your good to go
pics would help, cause the crank could have been changed at some time
