Wiring 4l80e to LS1 w/T56
Did some reading and I noticed alot of you guys use the wiring harness from an a4 then use an adapter harness to make it work with the 4l80e. I also found a company(begins with Spear) that has a wiring harness that can be used from t56 to the 4l80e without switching to the 4l60e harness first.
Has anyone ran the premade conversion harness on their car? If so, how was the install etc. Going the A4 seems the easiest as I dont have to repin the PCM harness(or do i?) but being in Alaska Im limited on parts.
Thanks!
Thanks!
Gingervitis Addict
Thanks!
Thanks!
