trans temp?
Old May 3, 2011 | 06:20 PM
01BlackCamaroSS's Avatar
Default trans temp?
So i installed my rebuilt performabuilt level 2 trans back in march. I also swapped out my old trans cooler for the hayden one that the supply with there trans. Driving around the trans would get up to 190-200 plus range i never saw temps like this before unless i was really getting on it or at the track. I went ahead and ordered the b&m trans cooler figuring the hayden unit was not as effiecent. so i installed it today and then went on a 20min drive and when i return home the trans was at 200. i really want to figure out what is going on before cruisin weekend in a few weeks. any help would be awesome
Old May 3, 2011 | 07:24 PM
FastKat's Avatar
Did you have the Vig converter before you installed the new trans, or did you install it for the first time with the trans?
200 degrees isn't dangerously hot. I think a lot of guys here like ice-cold trans fluid though.
Where are you getting your trans temp reading from? Where did you install the sending unit?
Old May 3, 2011 | 08:27 PM
i got a newcircle d converter. it put it in when i reinstalled the trans. im using a interceptor gauge as well as a gauge i have the sending unit in the pan its the same spot it was before its the same pan.
Old May 3, 2011 | 08:50 PM
FastKat's Avatar
Well, part of the change in temperature might have something to do with the Circle D converter.
How close are the Interceptor gauge and the one reading from the pan? I think the sending unit that the interceptor reads off of is usually a little higher than what you see in the pan because of its location.
Old May 3, 2011 | 08:59 PM
senicalj4579's Avatar
I have that guage and I "have heard" that it will read a little higher than a aftermarket trans temp sender because the stock sensor is in a different place than the aftermarket would be. I cant comfirm if thats the case but I wish it was because my temps seem alot higher than alot of guys report on here. I have 3600 stall and so far this spring at 70f I have been 180f with trans temp. Im not very worried about it because the sponsor says this...read #4...https://ls1tech.com/forums/7412061-post4.html
Old May 3, 2011 | 09:07 PM
they are about 20-30* diffrn the interceptor being the higher
Old May 3, 2011 | 09:21 PM
Are you sure its that much of a difference?
When you got home from 20 min drive was the aftermarket sensor reading 200 or the interceptor? If it was the interceptor reading 200 then isnt that your answer to why its so high?
Last edited by senicalj4579; May 3, 2011 at 09:50 PM. Reason: I meant to say interceptor
Old May 3, 2011 | 09:43 PM
performabuilt's Avatar
LS1Tech Sponsor
Yes the one that measures using the trans internal sensor will measure higher because in reality its measuring the valvebody and case temp more than the fluid temp. Also if your running through the raditor to the temp will always closley follow engine temp too.
However the temps you are getting are well within normal range,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 3, 2011 | 09:48 PM
How much higher does the stock trans temp sensor really read than an aftermarket gauge? Is it really 20-30f higher?
Old May 3, 2011 | 10:32 PM
LS1Tech Sponsor
typically somewhere in that range and in fact can be more they are notoriously inacurate I have measured across them and got multiple readings in the same enviroment
__________________
Call 888-744-6542
Old May 3, 2011 | 11:09 PM
So it probably should be noted in a sticky somewhere that trans temps will read 20-30f higher for the guys who are reading temps from stock sensor. I was starting to think that I might have issues in hot summer seeing how its only early spring and im seeing 180f trans temps already. But now I know my interceptor is reading 20-30 higher than an aftermarket sensor. Great info thanks.
Old May 4, 2011 | 07:47 AM
i bypassed the radiator.i understand the temps being diff. i just is higher then it previously was prior to the trans getting rebuilt. amd yes i had a vig stall in it prior. i guess im just paranoid bout killing the trans again.
Old May 4, 2011 | 09:21 AM
FastKat's Avatar
Which gauge is giving you the 200* reading - the Interceptor or the pan gauge?
If your temps are that high, you might benefit from running the trans fluid through the stock cooler on the radiator tank. That will bring the fluid temp down closer to the coolant temp in the side of the tank (which is cooler than what's in the engine) before it goes into the separate trans cooler.
Old May 4, 2011 | 12:43 PM
yeah the interceptor reads 200. im gna take it out again today and see what it does
Old May 4, 2011 | 02:37 PM
FastKat's Avatar
If your Interceptor is reading 200* while your pan gauge is around 170*-180*, you're right where you want to be.
Old May 4, 2011 | 04:29 PM
ok kool thanks for the help
