flt level4 binding up
Old Jul 25, 2011 | 12:10 PM
z99ls1's Avatar
Restricted User
Originally Posted by Andy @ FLT
We would be happy to try to help no matter what it is, but you need to call...
LOL he hasn't called you guys yet? Come one man if you don't call they can't do much for you. I'm sure they could help you better than anyone
Old Jul 25, 2011 | 12:52 PM
regblkss's Avatar
Yea my girlfriend called this morning. I'm pulling it back out this weekend. And sending it into them. They are going to pull it apart and help fig out what in feeling.. she said you guys were great!! And again why I picked them to do business with.
Old Jul 25, 2011 | 01:20 PM
heymoej's Avatar
before i pulled the trans,
i would seriously have someone NEW look at your tune...... tuners are not perfect & miss things,i had it happen to me.
have you checked your air cleaner & maff for excess oil? to much oil can make an auto tranny act up....
good luck!
Old Jul 25, 2011 | 04:31 PM
regblkss's Avatar
Well when I took the car back to have the tune check for the limp codes to make sure it was deleted we check all the sender and even swamped one of his old maf on it to make sure it wasn't the problem. We check the tps and map also.
Old Jul 25, 2011 | 07:58 PM
Slowhawk's Avatar
LS1Tech Sponsor
I have a feeling the tranny is fine.If it was screwed it would show up during normal driving. Sounds like a VSS problem in the computer. You have to do 1/4 runs with a scanner hooked up to find the problem.
Old Jul 25, 2011 | 08:05 PM
Kevin01Z28's Avatar
Originally Posted by regblkss
Well the car was tuned by a professional. I don't have a the program is what I meant to say. Its only a problem with 2nd gear I think. It binds up then when it hits 3rd its like a different car. And then after that the next pass it does the "LIMPMODE" thing when I only have 2nd gear. Been to the track 2 times same results both times. Yet normal driving shift and feels fine.
If its going into limp mode thats the tune, only thing it can be. And since its doing that, it leads me to believe the other problem is tune related. When I first installed my trans/stall combo it went into limp mode under normal driving conditions even after a mail order tune. I got tired of sending my pcm back and forth so I bought hptuners and did it myself. Glad I did too...
After I bought hptuners and checked my mail order tune, I noticed a descrepancy between the WOT mph column and the part throttle 100% columns. This was after my tune was checked twice. We are human and all make mistakes. Your tuner may have overlooked something, even when he checked it again. Hell when he checked it the second time he may have just deleted P0757.
Seriously, before you go through the trouble of pulling the trans, completely draining it, crating it up and hauling to a freight terminal I would get it tuned properly. You say you have 20k in the car, whats another 500 or 600 bucks for a dynotune if it could keep you from burning up your trans???
Old Jul 25, 2011 | 08:32 PM
regblkss's Avatar
OK. I guess ill try a new place to get it tuned at. Thinking of going to new era.
Old Jul 26, 2011 | 09:18 AM
Andy @ FLT's Avatar
Like I said if you need us we are here for you,but the last thing you want to do is pull the trans and find out its not the problem. Thanks Playa and Kevin and everyone else trying to help out here.
Andy
Old Jul 27, 2011 | 09:44 PM
regblkss's Avatar
OK I have date this sat to get it dyno tuned at new era. What do I need to have Mike look at as far as tune for the transmission?
Old Jul 28, 2011 | 05:58 AM
Vince B's Avatar
Moderator
regblkss check with your tuner to make sure that the "test" for the P0751 and P0757 are deleted in your tune. I guess its possible that he might just have the report part shut off in the tune. That would explain as to why you do not get a light. Also when the trans seems to go into limp mode do you have to shut the car off to correct the condition?
I personally would get a scan tool on it to see what the computer is actually commanding the trans to do when this condition actually happens. This might help to better decide where the issue really is. First gear both the "A" & "B" solenoids are on. When the trans is in second gear the "A" solenoid is off with the "B" solenoid on. Third gear they are both off and for 4th the "A" solenoid comes back on.
This should give you a better idea as to what the trans should see from the computer and what gear is being commanded. From there you should be able to look at engine rpm and the calculated output rpm (VSS) to figure out what gear you are really in. This should tell you if in fact the issue is trans related or vehicle related. Good luck getting this sorted out. Vince
Old Jul 28, 2011 | 10:51 AM
Andy @ FLT's Avatar
Please take it to your tuner and if he has any questions he can give us a call.
Vince is NOT a tuner and I would ask that he not try and complicate the issue any further.
Old Jul 28, 2011 | 11:30 AM
  #32
RevGTO's Avatar
Pontiacerator
How is Vince complicating the issue? His advice is right on target. The OP needs to delete the proper DTC's and scan some runs before he will have any idea if the tranny is working properly. No brainer. If his tuner knew what he was doing, most likely he wouldn't be having the issue.
Old Jul 28, 2011 | 12:00 PM
  #33
Andy @ FLT's Avatar
Please, I'm not looking for trouble here, we have a plan. Let him take it to the tuner and we wil go from there.
Thank you.
Old Jul 29, 2011 | 09:41 AM
  #34
regblkss's Avatar
thanks for the help I'll let everybody know how it went saturday afternoon.
Old Jul 31, 2011 | 01:36 PM
  #35
regblkss's Avatar
OK. So after the tune. Everything's seem fine. I like to thank recommend flt for being support. And why I went with them to get a new transmission. I highly recommend them. And a big thanks to Mike at newera performance. He got my car all fixed. It is now everything I wanted and worked for all winter long. Now time for some 10's with h/c set up
Old Jul 31, 2011 | 01:41 PM
  #36
z99ls1's Avatar
Restricted User
Originally Posted by z99ls1
Only thing I can say is get the car tuned and see what that does
I think I called it also lol.
Old Jul 31, 2011 | 02:41 PM
  #37
heymoej's Avatar
good deal........congrats!
Old Jul 31, 2011 | 03:28 PM
  #38
z99ls1's Avatar
Restricted User
Yes and very good to see you got it figured out man. That's good cuz I will go with flt if and when my trans goes. Hopefully not for a long time.
Old Aug 1, 2011 | 09:44 AM
  #39
MBC Racing's Avatar
So, what did New Era find was wrong in your tune that was causing the problems?
thanks
Old Aug 1, 2011 | 09:48 AM
  #40
Andy @ FLT's Avatar
Glad to hear all is well.
