4L80E output shaft question
early have short splines and o ring, later longer splines maybe????
anyway, on the short spline with the o ring, do you need a yoke with the hollow area to slide over the seal, or can you just use a reg 400 yoke
what does the o ring do anyway-i remember on the old 400's, they used it with a yoke with a hole in it to let air out when it slid-sure caused a lot of leaks when it was used in non o ring trans, lol
Same as a truck style TH400.
You can use a stock TH400 yoke, the issue is that if you look at the spline engagement, you are giving up some engagement to have the proper amount of travel for normal yoke slip.
We machine the output shafts so a normal yoke will go past the splines about 3/4", so there is always complete or near complete spline engagement.
http://www.jakesperformance.com/TH400_Components.html
The TH400 output shafts are essentially the same as far as the yoke is concerned.
You can see the o-ring groove and how close it is to the splines.
Depending on application you need about 1" of yoke slip.
As you can see in the pic you would be giving up almost an inch of spline engagement.
We machine the shafts so that the yoke can go further in the trans and retain full spline engagement. This assures more power capability and less likely to have driveline vibrations.
The average consumer thinks they should just use a hacksaw to fix a clearance issue.
You can cut down a yoke but there are correct ways of doing it and I would recommend doing things the correct way.
USUALLY I recommend installing the yoke until it bottoms, pulling it out 3/4"-1" and then cutting the driveline to fit.
Look at how the original end looks, make your newly cut end look the same.
Would you still think the same thing when I voided your warranty on a transmission that had thrust washer damage?
i usually meas the distance from trans to rear with full weight on the rear, then with it hanging, see how much the yoke will move
hanging loose it will usually be closer-i try and fit them as tight as possible, but not to tight where it would ever bottom out
