wont 2-3 shift at WOT
Old Feb 27, 2004 | 02:18 PM
417 Motorsports's Avatar
Question wont 2-3 shift at WOT
ok the car is a 98 z28 that was programed by the previous owner and unfortunatly i do not have the programer... BUT the problem is that its shifting at 6600 in D at WOT from 1-2 but it will not shift from 2-3 unless you lett off the throttle at 55ish. It does have a shift kit in it but i do not know what brand i have heard B&M will cause problems but...?
Now could this be a reprogramed problem or valvebody?
recently the tranmission has been slipping in OD and if you put the car in first and take off it will take off in second..... now this has just recently started and i have owned the car for about a month but the 2-3 problem has always been there....
i am pulling the trany this sunday to get it built and put the TCI SSF in it.
Blake
Old Feb 27, 2004 | 07:07 PM
Anyone
Old Feb 28, 2004 | 12:49 AM
VT2 EXEC LS1's Avatar
Sounds like your 3-4 clutchpacks are burnt out. Maybe the 2-4 band is stuffed too.
Old Feb 28, 2004 | 07:08 AM
00a4z28's Avatar
Same symptoms you had and it was the 3-4 clutches
Old Feb 28, 2004 | 11:35 AM
So the worn 3-4 clutches can cause it to not **** at WOT from 2-3?
Old Feb 28, 2004 | 08:32 PM
Yep, and eventually your trans wont provide any drive in 3 or 4.
Old Feb 29, 2004 | 09:09 PM
00a4z28's Avatar
The clutches have enough material left to hold at part throttle but not at wot. VT2 is right eventually 3 and 4 will completely go away.
