46l0E will not drop into gear
Old Jun 24, 2011 | 08:45 AM
19blackSS98's Avatar
Default 46l0E will not drop into gear
i did a rebuild on my engine and had to pull the trans with it. My friend hooked the trans up and everything seems to be connected but when we go to shift the car into any gear it will not move. I only bought 3 quarts of trans fluid not realizing how much i really need. Is it possible the trans will not shift due to not enough trans fluid?
Old Jun 24, 2011 | 12:11 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
yes,when I swapped trannys and a new(empty) convertor,I had nothing until fluid level was to where it should be.
Old Jun 24, 2011 | 02:03 PM
ok thanks im almost positive thats all it is.
