th400 problems
Old Jul 2, 2011 | 02:30 AM
kalildude's Avatar
Default th400 problems
i have a th400 with a 3800 stall and it seems like the top speed is 80 mph. do th400s shift at a different rpm? why does it basicly max out at 80?
Old Jul 2, 2011 | 05:28 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
What is the gear in the rearend
Old Jul 2, 2011 | 10:28 AM
SuperSlow02's Avatar
Are you sure your shifting into 3rd. I have a 4.11 rear gear and I'll top out at 135-140
Old Jul 8, 2011 | 03:08 AM
kalildude's Avatar
4.11 it shifts at 5500rpm and yea its in third.
Old Jul 8, 2011 | 09:34 AM
What rpm is it pulling at 70mph?
Old Jul 9, 2011 | 05:35 AM
kalildude's Avatar
5000 range
Old Jul 9, 2011 | 08:18 AM
Duffster's Avatar
4.11 in 3rd gear should be near 3900ish
You're still in 2nd gear...
http://www.kabamus.com/garage/gears.html
based on a 1st gear - 2.48, 2nd gear - 1.48, 3rd gear 1.00
Old Jul 9, 2011 | 10:51 AM
Do you have a ratchet shifter in the car? That would easily cause the problem without you knowing
Old Jul 9, 2011 | 06:46 PM
kalildude's Avatar
i swear im in third i did a dig and it shifted twice. no i fabricated a bracket to where i can use my stock shifter
Old Jul 9, 2011 | 06:50 PM
kalildude's Avatar
i went to that website. see what you find out? i have 305/45/18 drags and its saying at 6500 rpm my mph is 84 something?
Old Jul 9, 2011 | 09:14 PM
Duffster's Avatar
yes, 84.5 at 6000 rpm in 2nd gear!
125.1 at 6000 rpm in 3rd gear
RPM - 8000 7500 7000 6500 6000 5500 5000 4500 4000 3500 3000 2500 2000 1500 1000
3rd Gear 166.8 156.4 146 135.5 125.1 114.7 104.3 93.83 83.41 72.98 62.56 52.13 41.7 31.28 20.85
2nd Gear 112.7 105.7 98.62 91.58 84.53 77.49 70.45 63.40 56.36 49.31 42.27 32.22 28.18 21.13 14.09
Old Jul 11, 2011 | 04:58 AM
kalildude's Avatar
I have a stock motor but it is procharged and running 7 pounds. I don't get what's wrong. I did hit 100 just recently and that was at 6500 rpm
Old Jul 19, 2011 | 12:37 AM
fastsspr's Avatar
Man you going to hurt that motor doing that. I think too you are in second gear!
Old Jul 19, 2011 | 11:00 AM
Heads-Up-Outlaw's Avatar
What is the fluid condition? It could easily be that you're blowing through the converter. Was the converter built specifically for your combination?
Is the tranny equipped with a brake? What is the max stall speed of your converter?
